It would be nice if you could right-click on the Trash Smart Folder and tell it to empty trash. Right now, if you want to empty all of your trash, you need to go the specific account Trash folder and empty it. As I hardly ever close out eM Client, having it empty trash on exit is not really a feasible solution. It would be nice to be able to empty trash from all accounts all at once.
Well, somehow my search did not turn up related conversations on this topic until after I posted…
Hi, thank you for the suggestion, it would actually make a lot of sense, I’ll suggest this idea to the developers and we’ll consider adding the feature to future releases.
Thank you for your input on this,
Was wondering if this might make it into v7?
Hello, this feature has been added to our todo list to upcoming updates, it should be included in version 7 as well.
It should…but unfortunately its not in V7…Not sure how difficult this would be to include a right click on the smart trash folder and just do a global trash delete from each account. Or if you wanted to be fancy, have a setting in each account to tell the smart folder whether or not you wanted it to empty that particular accounts trash or to keep it, or to delete after so many days…
And 4 years later, this is still not a feature as stated that it would be…
