is it possible to run eMClient with Crossover by Apple ́s OS Lion? The other Programs from Softmaker Office 2012 are running by OS Lion very well.
Doubt it would work. As eM Client is based on .NET framework. I have yet to known any way to run .NET framework 100% beside on a Windows PC. You need to use proper Windows on your mac. Using virtualization or bootcamp.
Thank you.
Within the environment of VMware the eMClient works without problems. But I want to switch from VMware on a pure Mac OS enviroment; the few Windows Programs I want to use under Crossover.
According to the website from crossover it seems that the Versions 3.5 and 4.0 from MS Network does not work
EM Client requires .NET 2.0 SP2. You’re always welcome to try. But don’t be surprised if it doesn’t work. Even for Windows, .NET isn’t the best things around…
“Even for Windows, .NET isn’t the best things around…”
That is probably true.
