I have the some problem - “checking for corupted database - failed” and here are some details
System.Data.SQLite.SQLiteException (0x80004005): disk I/O error
disk I/O error
at System.Data.SQLite.SQLite3.Prepare(SQLiteConnection cnn, String strSql, SQLiteStatement previous, UInt32 timeoutMS, String& strRemain)
at System.Data.SQLite.SQLiteCommand.BuildNextCommand()
at System.Data.SQLite.SQLiteCommand.GetStatement(Int32 index)
at System.Data.SQLite.SQLiteDataReader.NextResult()
at System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
at System.Data.SQLite.SQLiteConnection.Open()
at MailClient.Storage.Data.DataStore.GetConnectionInternal(String relativeName)
at DbRepair.CorruptionChecker.CheckCorruption(RepairOptions repairOptions, CancellationToken token)
at DbRepair.CheckingProcess.Check(CancellationToken token)
Data:
SQLiteCommandText: PRAGMA synchronous=Normal
databaseFile: 0cf98b37-359e-4242-b724-1447be8ef21f\0d0a6e08-17fe-4b30-a985-27f2072e6f6c\mail_data.dat
Paul, your best bet is to download the current version of eM Client from https://www.emclient.com/download and see if there is any difference.
V, unfortunately if there is an issue with the database that cannot be corrected, then your best option will be to delete the current one, and either start again or restore from your most recent backup. To delete the database either rename or delete the C:\Users\yourusername\AppData\Roaming\eM Client\ folder. You may have to enable hidden items in Explorer to get there.
