eMClient crashes when starting up every time after I rebootet my PC.
The following I get from the system log:
Application: MailClient.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: exception code c0000094, exception address 6DA516D4 Stack: at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG ByRef) at System.Windows.Forms.Application+ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr, Int32, Int32) at System.Windows.Forms.Application+ThreadContext.RunMessageLoopInner(Int32, System.Windows.Forms.ApplicationContext) at System.Windows.Forms.Application+ThreadContext.RunMessageLoop(Int32, System.Windows.Forms.ApplicationContext) at MailClient.Program+\<\>c.<main>b__90_1()
at System.RuntimeMethodHandle.InvokeMethod(System.Object, System.Object[], System.Signature, Boolean)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(System.Object, System.Object[], System.Object[])
at System.Delegate.DynamicInvokeImpl(System.Object[])
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
at System.Windows.Forms.Control.WndProc(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.ScrollableControl.WndProc(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.ContainerControl.WndProc(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.Form.WndProc(System.Windows.Forms.Message ByRef)
at MailClient.Common.UI.Forms.BaseForm.WndProc(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.Control+ControlNativeWindow.OnMessage(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.Control+ControlNativeWindow.WndProc(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr, Int32, IntPtr, IntPtr)
at Xilium.CefGlue.Interop.libcef.run_message_loop()
at Xilium.CefGlue.CefRuntime.RunMessageLoop()
at MailClient.Program.Main(System.String[]) </main>
followed by
Faulting application name: MailClient.exe, version: 7.1.30794.0, time stamp: 0x597869a0
Faulting module name: nViewH.dll, version: 6.14.10.14847, time stamp: 0x58524f12
Exception code: 0xc0000094
Fault offset: 0x000816d4
Faulting process id: 0xb18
Faulting application start time: 0x01d34d7e88d903ba
Faulting application path: C:\Program Files (x86)\eM Client\MailClient.exe
Faulting module path: C:\Program Files\NVIDIA Corporation\nview\nViewH.dll
Report Id: 2aeef932-21b9-4277-b4f3-f16fde24adb4
Faulting package full name:
Faulting package-relative application ID:
Any ideas?
