I receive on daily basis e-mails which contain images in the body that are so big, that I need to click on them, so they are opened in the Windows-image viewer. Is it possible to resize the embedded images to viewport size while browsing the mail?
eM Client doesn’t offer that option for embedded images, but you can zoom in and out of the message using Ctrl + or Ctrl - (reset using Ctrl 0), or by holding down the Ctrl key while scrolling up and down with your mouse wheel.
ok, thank you. Let’s give it a try
