Email does not exist on mobile eM client
Emails (3 times from 1&1) only appear on the PC (W11). Even after several updates of the mail account, the emails do not appear. E-Mails are transfered via Exchange-Server.
It seems to be a special email, since the other emails (probably most of them) appear on both devices (PC and phone).
If emails are not all appearing on the mobile app but do all appear on the desktop that could be happening for a few reasons.
1). If the Exchange account has only just been added and has not completed the initial sync yet from the server end, so could just be taking time depending on the size of your online mailbox.
So to see if it’s still synching mail, press “Menu / Settings / Show Operations”.
2). If it’s not synching anything and no errors in the Log Tab, then could be a problem with the local account cache in the mobile app. So to clear the account cache and start new, “press and hold your finger on the Inbox” and press “properties” at the bottom. Then scroll down and press “Repair” at the bottom. Once the local cache is cleared, your messages will start appearing back in the app shortly and will be slower to reread till fully cached. So be patient once the cache is cleared.
3). If clearing the app local mail cache still doesn’t show all your Exchange acct messages, then suggest you press “Menu / Settings” and remove and readd your account via the automatic wizard.
Lastly if removing and readding your Exchange account still is not showing all your messages, you might then have Inbox Categories enabled in the mobile app so the missing messages could be in another Inbox tab like Other. You can see if you have Inbox Categories enabled via pressing “Menu / Settings / Mail / Categories”.
