System.Data.SQLite.SQLiteException (0x80004005): database or disk is fulldatabase or disk is full
bij System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)
bij System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt)
bij System.Data.SQLite.SQLiteDataReader.NextResult()
bij System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
bij System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
bij System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
bij MailClient.Storage.Data.DataStore.GetConnection(String relativeName)
bij DbRepair.CorruptionChecker.CheckCorruption()
bij DbRepair.FormCheck.Check(Object state)
Hard disk has >500Gb free space
Same problem. Was just sending an email when it happened.
Now it is useless.
Hello everybody,
We’re sorry that you’re experiencing this issue. Could you please post a screenshot of the hard drive properties?
Maurice
I fixed the problem by just deleting the mail.dat and index files. It is now downloading the emails from the server which will take a few hours. To delete every file and all the settings was not a solution.
