The eM Client will not start in Windows 11 after the last update. Running a new installation downloaded from the web says I already have the latest version and quits. Do you know what I can do? Uninstalling eM Client won’t lose my email database? Thank you.
Addendum: The eM Client process (32 bits) or the MailClient.exe process (32 bits) appears briefly in the Task Manager and terminates immediately. Why?
Appendix 2: Running as administrator did not help.
And sfc /scannow : Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection did not find any integrity violations.
Appendix 3: Is anyone from eM Client reading this forum?
same issue with me
Close and uninstall eM Client, making sure NOT to delete the database folder when asked. That will ensure all your data and settings are there later.
If it exists, delete the C:\Program Files (x86)\eM Client folder.
Download and install the latest version from here: https://www.emclient.com/dist/latest/setup.msi
Restart eM Client.
Thank you. Good work. eM Client works OK.
I guess the explanation. I was offered emclient-v9.2.2157.msi, but now it is emclient-v9.2.2258.msi. Anyone who updated immediately like I did probably has the same problem. But thanks to you this problem is solved.
For eM Client: before you release a new update, test it properly! (Otherwise you are making life unnecessarily difficult for your customers .
Translated with DeepL Translate: The world's most accurate translator (free version)
