eM Client program will not open. States that it did not close properly with an error box and tries to repair (database check). Repair does not work and tells me to contact you.
Try to update the eM Client to this and see if it works: http://www.emclient.com/dist/v5.0.177…
if you still encounter this problem, post here a screenshot of the error message. Thank you.
System.Data.SQLite.SQLiteException: The database disk image is malformed
malformed database schema (LocalMailsIndex3_contentIndex) - no such table: main.LocalMailsIndex3_content
at System.Data.SQLite.SQLite3.Prepare(SQLiteConnection cnn, String strSql, SQLiteStatement previous, UInt32 timeoutMS, String& strRemain)
at System.Data.SQLite.SQLiteCommand.BuildNextCommand()
at System.Data.SQLite.SQLiteCommand.GetStatement(Int32 index)
at System.Data.SQLite.SQLiteDataReader.NextResult()
at System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
at System.Data.SQLite.SQLiteConnection.Open()
at DbRepair.DbTools.OpenConnection(String fileName)
at DbRepair.Form1.CheckCorruption()
at DbRepair.Form1.Check(Object state)
Sorry, CHAMP - the link you gave me did not fix the problem. But thanks for the reply.
That error message referrs to corruption of database. You need to delete them and start fresh. Database can be find:
C:\Users%Current User%\AppData\Roaming\eM Client (Vista/Win7)
C:\Documents and Settings%Current User%\Application Data\eM Client (XP)
TNCS is right - you will have to restore your data from a backup or delete the database and start with blank database.
