To setup a new database you have to go to your local folder > App Data > Roaming, and either rename or delete the eM Client folder, which contains your database files.
However, this issue may not be caused by a database faulty.
Thank you for your response. I updated the .NET framework to make sure I was running 4.5.1 and it had no effect on the issue that i am having. eM Client is the only program I am having an issue with after cleanup of the PC.
I also deleted the existing database from the roaming folder. After doing that, this is how it appears after starting eM Client.
Thanks again for your time!
Simon
Hi again, can you please send me an email with a reference link to this forum topic to [email protected]?
