Is anyone else having problems printing messages after upgrading to v9 on Windows 10?
If I open a single message and select Print the Windows dialog opens and can print that message.
However, if I select one or more message displayed in the Inbox and right-click Print, nothing at all happens. Same if I select Print from the menu with one or more inbox items selected.
Interesting. Yes, I have auto-update on, in Windows 10 and the very latest updates installed. John_A who responded above is having the same issue. Wonder if he’s on Windows 10?
I’ve checked my Windows 10 (19044.1706) on emClient (9.0.1708 (2cfb4a5)) selecting one, two and more Mails on the inbox view - took some seconds to prepare the PreviewPDF, but worked like a charm.
So here, everything works fine.
I have tracked this bug down!
I always have Menu > View > Layout - Messages panel OFF
I changed the setting to “Messages on the right”, Right click > Print now works
Turn Messages panel OFF, Right click > Print still works
But when I restart emClient (with messages panel off) - Right click > Print doesn’t work again
Assessment:
Definitely a bug in em Client
Temporary workaround:
turn on either Menu > View > Layout - Messages on the right or messages on the bottom.
Note: If you already have Messages panel on right or bottom, turning Messages panel off will not introduce the bug until you restart em client
