em client slow synchronizing with gmail. I started noticing this about a month ago, and my database is only 540mb. Anyone noticing this? System is virus and malware free, I am a Technology Specialist for the State I reside in. Maybe a corruption in the db? Win 7 64bit i7Intel, 16gb ram, full windows updates.
Hello Cory, sorry to see this, but I’m not quite sure what kind of slow synchronizing you’re referring to, what version of eM Client are you currently using on your computer, can you please check the exact release number in Help > About? Are you seeing any errors while synchronizing the application with the server?
You can download and run this database repair utility and check for database corruption, however if you’re able to use the application, I don’t believe database corruption may be a root of this problem.
Download the utility at http://www.emclient.com/tools/dbrepairrebuildall.exe
I am using the following version: 6.0.22344.0
I will try the utility. I checked my AV prg to make sure nothing was getting hung up there. Weird.
I should also note this is an imap connection to a Gmail account.
