When I send email from my Gmail account, the rule works.
When I send email from Outlook, it does not. The email shows in the normal Sent folder in Outlook, but not in the SENT folder under Archive.
It is because there is no message for the Rule to move or copy at the time you click on Send. The MS server creates the message in its Sent folder some time later, and then it is synced back to eM Client via IMAP.
These Rules that apply to sent messages normally only work where eM Client creates the sent message itself.
But it works OK for Gmail. The email goes into the SENT folder in Archive. But it is different from Outlook - Gmail does not send it back to the Sent (Gmail) folder on my eM Client.
I do write the message in eM Client, and click the Send button in eM Client item. What more can I do?
Can you suggest a work-around? Any other rule? Or new rule perhaps??
Or should I automatically archive the Outlook Sent folder every day? What triggers the auto archiving - when I switch the PC off at night, or something else?
The eM Client team could consider doing something about this.
Internet service providers are shifting email work to specialist email companies, and they will want us to pay for it.
The answer is to go Outlook or similar… There is added advantage in this - shopping around and changing internet providers without affecting one’s email address.
It is not a flaw, it is just the way the server does it.
Yes, a copy of the message is kept. The server creates it in the Sent folder. You can see that yourself, just click on the Sent folder either in eM Client or in webmail.
I said before that I can see the sent message that comes back from Outlook server.
The question was how long will it stay there?
Is it dependent on eM Client setting, or is it wiped out by Outlook server every day, or what?
If I could somehow find a way to keep them there indefinitely, until I myself delete them, that would help.
