Why does this message keep appearing?
This is a Windows 10 issue (I assume you use Windows 10?). To fix, do the following:
- Go to Windows Settings/System/Default Apps
- Make sure eM Client is the default email app.
- At the bottom of that page, click on “Set defaults by App”
- In the left pane, click on eM Client
- Select “Choose defaults for this program”
- Check “Select All”
This should solve your issue.
