I have configured IMAP for my account
- enabled IMAP in zoho acc
- added application specific password, since OTP is enabled
- configured em Client with
and got error
17:49:05.555|001| AccountBase.ChangeOnlineState : STATE CHANGE TO online due User
17:49:05.555|001| eM Client 8.2.1659.0
17:49:05.557|081| >>> ListFoldersAsync(): Start
17:49:05.557|081| 01: Connecting to imappro.zoho.eu:993...
17:49:05.559|019| >>> Starting account synchronization
17:49:35.605|019| 01: --- CLOSE: PRIMARY START
17:49:35.606|08A| 01: A1 LOGOUT
17:49:35.611|019| 01: --- RECEIVE: EXCEPTION: System.IO.IOException: Unable to read data from the transport connection: The remote host forcibly terminated the existing connection..
---> System.Net.Sockets.SocketException (10054): The remote host forcibly terminated the existing connection.
--- End of inner exception stack trace ---
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken)
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.GetResult(Int16 token)
at MailClient.Imap.Base.Extensions.CopyToAsyncWithTimer(Stream source, PipeWriter writer, TimeoutTimer timer, ITaskSource readDemandSource, Action`1 loggingCallback, CancellationToken cancellationToken)
at MailClient.Imap.Base.TransportPipe.StartReading(Stream stream, CancellationToken token)
at System.IO.Pipelines.PipeCompletion.ThrowLatchedException()
at System.IO.Pipelines.Pipe.GetReadResult(ReadResult& result)
at System.IO.Pipelines.Pipe.GetReadAsyncResult()
at System.IO.Pipelines.Pipe.DefaultPipeReader.GetResult(Int16 token)
at MailClient.Imap.Base.Extensions.<>c__DisplayClass30_0.<<ReadLineAsync>g__SlowAsyncPath|1>d.MoveNext()
--- End of stack trace from previous location ---
at MailClient.Imap.Base.TransportPipe.LoggingHandler(PipeReader fromReader, PipeWriter toWriter, CancellationToken cancellationToken, String name)
at MailClient.Imap.Base.Connection.ReceiveAsync()
17:49:35.611|019| 01: --- RECEIVE: CLOSED
17:49:35.611|019| 01: --- CLOSE: SECONDARY START
17:49:35.918|019| 01: --- CMD LOGOUT WAS CANCELLED
17:49:35.918|019| 01: --- CLOSE: LOGOUT TIMED-OUT !!!!!!!!!!!!!!!
17:49:35.919|019| 01: --- CLOSE: PRIMARY FINISHED
17:49:35.919|08A| 01: --- CLOSE: SECONDARY FINISHED
17:49:35.923|081| >>> COMMAND CONNECTION EXCEPTION (retry: True): MailClient.Accounts.ConnectionException: Failed opening connection to server.
---> System.IO.IOException: No server response within 30 second timeout.
at MailClient.Imap.Base.Connection.ConnectAsync(Func`2 getStream, CancellationToken cancellationToken)
at MailClient.Protocols.Imap.ConnectionPoolEntry.ConnectInternalAsync(CancellationToken cancellationToken)
at MailClient.Protocols.Imap.ConnectionPool.AcquireConnectionAsync(Folder mailFolder, Boolean noSelect)
at MailClient.Protocols.Imap.ConnectionContext.CreateContextAsync(ImapAccount account)
at MailClient.Protocols.Imap.ImapFolderSynchronizer.ListFoldersAsync(IListFoldersProgress progress, Folder homeFolder, CancellationToken cancellationToken)
at MailClient.Protocols.Imap.ImapFolderSynchronizer.GetFolderList(IListFoldersProgress progress, Folder homeFolder, CancellationToken cancellationToken)
at MailClient.Protocols.Common.FolderSynchronizer.<>c__DisplayClass14_1.<EnqueueGetFolderList>b__0(WorkerStatus status, CancellationToken cancellationToken)
at MailClient.Protocols.Imap.ImapActionCommand.<>c__DisplayClass13_0.<.ctor>b__0(WorkerStatus ws, CancellationToken ct)
at MailClient.Protocols.Imap.ImapActionCommand.ExecuteInternalSync(WorkerStatus status)
at MailClient.Protocols.Imap.ImapActionCommand.Execute(WorkerStatus status)
17:49:35.923|081| >>> ListFoldersAsync(): Start
17:49:35.923|081| 02: Connecting to imappro.zoho.eu:993...
17:50:05.999|06B| 02: --- CLOSE: PRIMARY START
SMTP works fine
could you please help me to resolve the issue?
P.S link to the topic in zoho forum https://help.zoho.com/portal/en/community/topic/em-client-got-error-for-imap
