Since this last version 8.2.1659
update, I have had eM Client freeze up on me multiple times even to where it has frozen my computer and I had to do a hard power off. I’m using Windows 10 and haven’t had problems this frequently. Sometimes when I click on an email the whole thing freezes, then blurs, and stops. Anyone have problems like this recently? I tried to reinstall the version and it tried to do a repair but it gave me the attached notice. Not sure what to do now.If you are comfortable executing these steps, give this a try:
(1) Delete any installation files you have downloaded.
(2) Uninstall eM Client, making sure to NOT delete your database directory when asked. This will ensure your settings and data remain in place.
(3) If it exists, delete C:\Program Files (x86)\eM Client
(4) Download and install the latest version from Release History.
(5) The latest version of eM Client should then start with all your data in place.
Thanks! I followed your directions and it installed with everything as before. I’ll give it a few days to make sure the problems I was having don’t happen again.
