I want to ask a question to you. We have a problem on Exchange EWS connections when we send or receive test.
Details ;
We use “eM Client” mail program to (http://www.emclient.com/) connect Exchange Server 2010 with EWS connection.
Every time getting an error prompt page when we send with attachment message. (a file / a zipped folder) size 10 MB or greater.
Error Messeage is below ;
“[Exchange Web Services] An attemp to connect to my[email protected]failed. This could be caused by temporary server unavailability or incorrect settings. Do you want to check the settnigs ?”
This error usually occurs every 100 seconds.
And then I check the “EWS throttling in Exchange” I think we use EWS as a default settings.
EWSMaxConcurrency : 10
EWSPercentTimeInAD : 50
EWSPercentTimeInCAS : 90
EWSPercentTimeInMailboxRPC : 60
EWSMaxSubscriptions : 5000
EWSFastSearchTimeoutInSeconds : 60
EWSFindCountLimit : 1000
I’m not sure helpfully solution to solving the issue. Please explain about the problem.
Thanks in advance.
