I am using eM Client v8 and I don’t seem to be able to create more than one alarm for an event.
Can anyone point me on how to do it and if this is even supported?
Cheers,
Filipe
Cheers,
Filipe
lunes 12 octubre 2020 :: 1042hrs (UTC +01:00)
Hi @c0nd3stav3l
If you mean at the same time on days into the future - YES
If you mean multiple alarms at different time for a single event on the same day, I haven’t found out how.
As a work around this is what I do…
If something is very important and I want multiple reminders: I create the number of alarms that I want at the time intervals I want each as a separate consecutive event.
Do you understand?
Lo entiendes?
Voce entende?
Skybat
¡Hola @skybat!
I meant multiple alarms at a different time on the same day, for a single event. I previously used Thunderbird, and that was supported… it is a shame that this is not supported in eM Client, as this is something a use(d) quite often…
Cumprimentos, desde Portugal!!!
Filipe
