em Client does not work with CardDAV on DSM 5.1
Yesterday i installed em Client. Its seems to be a very handy client.
So i tried to use my CardDAV contacts from my Synology, but i cannot get it to work.
i use the url http://:8008/address… but nothing happens.I also tried with https and 8443 as port.
I also tried the CalDAV Server on Synology (https://:5006/web/gr…) and it works for the appointments.
What am i doing wrong?
Hello Ralf, what version of eM Client are you currently using on your computer, can you please check the exact release number in Help > About?
Are you seeing any errors while trying to synchronize the account with the local server? Or are you unable to setup the account with eM Client?
Hello Paul,
I found the (real annoying) problem with DSM 5.1. My Synology got the local IP from my DHCP server (Fritzbox). After setting the network connection to “manual” i could connect eM Client to the CardDav server.
Hello Ralf, thank you for following with us, let us know if you come across any other issues or questions about the application, we’ll be happy to help.
