eM Client does not integrate with Murena.io
Tried everything, diagnoses OK, SMTP issues, sending not a problem but can’t receive mails in eM Client. Often diagnoses changes to ? and then OK again. Buggy situation and not stable.
Hi Ronald81,
Sorry for the trouble. Since sending works and Thunderbird receives fine, the incoming (IMAP) settings in eM Client most likely differ from the ones that work in Thunderbird.
  1. In Thunderbird, open the account’s server settings and note the incoming server name, port and connection security.
  2. In eM Client, go to Menu > Accounts, select the Murena account and open the IMAP tab. Enter the same server, port and security, and make sure the user name and password are right (Murena may need the full email address as the user name).
  3. Click Save & Close and restart eM Client.
The “?” in the Diagnostics tab only means the status is not known at that moment. The real error is shown in Menu > Operations… If receiving still fails, please post a screenshot of the Errors tab there (hide your address) and your eM Client version (Menu > Help > About), and we’ll look at it.
9:51:20.379|02A| SMTP S: 250-mail2.ecloud.global
19:51:20.379|02A| SMTP S: 250-PIPELINING
19:51:20.380|02A| SMTP S: 250-SIZE 502400000
19:51:20.380|02A| SMTP S: 250-ETRN
19:51:20.380|02A| SMTP S: 250-AUTH PLAIN LOGIN OAUTHBEARER
19:51:20.380|02A| SMTP S: 250-AUTH=PLAIN LOGIN OAUTHBEARER
19:51:20.380|02A| SMTP S: 250-ENHANCEDSTATUSCODES
19:51:20.381|02A| SMTP S: 250-8BITMIME
19:51:20.381|02A| SMTP S: 250-DSN
19:51:20.381|02A| SMTP S: 250-SMTPUTF8
19:51:20.381|02A| SMTP S: 250 CHUNKING
19:51:20.382|02A| SMTP C: AUTH PLAIN
19:51:21.922|02A| SMTP S: 535 5.7.8 Error: authentication failed: (reason unavailable)
19:51:24.119|02A| Exception: MailClient.Accounts.AuthenticationAbortedException: Authenticatie is afgebroken
19:51:24.119|02A| at MailClient.Protocols.Smtp.SmtpSendCommand.Authenticate(WorkerStatus status)
19:51:24.119|02A| at MailClient.Protocols.Smtp.SmtpSendCommand.Connect(WorkerStatus status)
19:51:24.120|02A| at MailClient.Protocols.Smtp.SmtpSendCommand.Execute(WorkerStatus status)
19:51:24.120|02A| at MailClient.Commands.Command.Process(WorkerStatus status)
19:51:24.120|02A| AccountBase.GoOfflineAsync : State changed to OFFLINE due LoginCanceled
19:51:24.122|00A| AccountBase.ChangeOnlineState : State changed to OFFLINE due LoginCanceled
In Thunderbird the settings are the same except STARTTLS
What is your Incoming Mail “server address, server port and security policy ?
Also what version of eM Client are you using ?
Do you have Windows or Mac & what OS ver ?
I appreciate your kindness Zyberzork but the eM Client is full of bugs and it is not the task of the user to study on errors to make it work ;-), focus on the basics (no errors) and then go further to pro-plans. Advice: open a Murena.io emailaccount for yourself and you will see it is not working at all. Nevertheless keep on the good work, but I am uninstalling this software.
Its not full of bugs. Sometimes you just need specific settings or sometimes strings etc depending on the server. But if you don’t want to advise any settings etc so we can check then thats fine.
I have reported these issues to Murena.io, as there are indeed two parties responsible for ensuring a proper connection. Their oversight is that, while they allow you to create an “application-specific password”—which only works for the calendar and cloud services—you are required to use your main account password for the email client. This is very strange and inconsistent. I suspect that this peculiar arrangement—involving the main password, application-specific passwords, and the 2FA linked to the primary account—is the root cause of the intermittent connectivity with the eM Mail client.
