This is a recent issue, where clicking on certain emails would crash it. I would delete them to avoid it. However its the top email currently from my daughters oncologist requesting a video appt. ever ytime it restarts, it crashes. I use a VPN and always have upto date kasperky’s security on. This has been going on for a week.. maybe 2 but intermittent until now.
here is the first part of the error message.
eM Client
10.3.2619.0
false
Microsoft Windows NT 10.0.26100.0
8.0.18
en-US
en-US
System.ArgumentException
An item with the same key has already been added. Key: Title:Video Consult with Dr. Dan Rubin, Start:09/25/2025 14:00:00, Local:09/25/2025 16:00:00, TZ:(UTC-07:00) Arizona End:09/25/2025 14:45:00, Local:09/25/2025 16:45:00, TZ:(UTC-07:00) Arizona
System.Private.CoreLib.dll
100672064
System.Private.CoreLib, Version=8.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e
System.ThrowHelper
ThrowAddingDuplicateWithKeyArgumentException
key
0
1b
100697317
System.Collections.Generic.Dictionary2</type> <name>TryInsert</name> <parameters> <parameter> <assembly>System.Private.CoreLib, Version=8.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e</assembly> <type /> <name>key</name> </parameter> <parameter> <assembly>System.Private.CoreLib, Version=8.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e</assembly> <type /> <name>value</name> </parameter> <parameter> <assembly>System.Private.CoreLib, Version=8.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e</assembly> <type>System.Collections.Generic.InsertionBehavior</type> <name>behavior</name> </parameter> </parameters> </method> <offset>0</offset> <nativeoffset>263</nativeoffset> <filename /> </frame> <frame> <method> <modulename>MailClient.Abstractions.dll</modulename> <metadatatoken>100663736</metadatatoken> <assembly>MailClient.Abstractions, Version=10.3.0.0, Culture=neutral, PublicKeyToken=null</assembly> <type>MailClient.Utils.CalendarUtils</type> <name>GetEventRelativePositions</name> <parameters> <parameter> <assembly>System.Private.CoreLib, Version=8.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e</assembly> <type>System.Collections.Generic.Dictionary
2[[MailClient.Schedule.Event.IEvent, MailClient.Schedule, Version=10.3.0.0, Culture=neutral, PublicKeyToken=null],[MailClient.Utils.CalendarUtils+EventSizeAndLocation, MailClient.Abstractions, Version=10.3.0.0, Culture=neutral, PublicKeyToken=null]]
eventsSizesAndLocations
System.Collections.Generic.IEnumerable1[[MailClient.Schedule.Event.IEvent, MailClient.Schedule, Version=10.3.0.0, Culture=neutral, PublicKeyToken=null]]</type> <name>EventsToShow</name> </parameter> <parameter> <assembly>System.Private.CoreLib, Version=8.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e</assembly> <type>System.Collections.Generic.List
1[[System.DateTime, System.Private.CoreLib, Version=8.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e]]
internalVisibleDays
