I just installed eM Client and got my exchange email going with it. But it’s crashing repeatedly. I have set the exchange server up like normal but I also have an alias on the account that I need to use. I’m not sure if this has anything to do with the issue or not. I’ve tried deleting the account completely and recreating as well as rebuilding the database using the database recovery tool you guys provide.
Here’s my error log:
eM Client (6.0.20648.0)Windows: Microsoft Windows NT 6.1.7601 Service Pack 1, Framework: 4.0.30319.1022
System.IO.FileNotFoundException: Could not load file or assembly ‘System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’ or one of its dependencies. The system cannot find the file specified.
File name: ‘System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’ —> System.IO.FileNotFoundException: Could not load file or assembly ‘System.Web, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’ or one of its dependencies. The system cannot find the file specified.
File name: ‘System.Web, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
at Microsoft.Exchange.WebServices.Data.HangingServiceRequestBase.ParseResponses(Object state)
at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx)
at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
