I have entered a wrong path in the CalDAV setup for an account in eM client which went unnoticed until I entered a new task.
Now I cannot open eM client anymore for that Windows 8.1 user:
An error has occurred in the application that prevents it from continuing…
The eM Client database check is run and found ok every time I start.
Is there a way I can delete this caldav account from the eM client database without using the GUI? I really don’t want to reinstall it and set it up from scratch again.
What is the path in Win8.1 to the database file?
Cheers
Thorsten
Here is the error message:
eM Client (6.0.19861.0)
Windows: Microsoft Windows NT 6.2.9200.0, Framework: 2.0.50727.8000
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: startIndex
at System.String.IndexOf(Char value, Int32 startIndex, Int32 count)
at System.String.IndexOf(Char value, Int32 startIndex)
at MailClient.CalDav.Synchronizer.GetFullPath(CalDavAccount account, Folder folder)
at MailClient.CalDav.Synchronizer.UploadCommand`1.Execute(WorkerStatus status)
at MailClient.Commands.SynchronizationQueue.ThreadWorker(Object threadData)
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ThreadHelper.ThreadStart(Object obj)
