I erased the malfunctioning eM Client program. When I downloaded the program again, like a zombie, the same old SQL database error reappears and will not load the newly down loaded program. Am I permanently shut out of eM Client?
Hi, this is because after removing the application, the original database is still kept on your computer, if you don’t have any data to lose, go to your local folder > App Data > Roaming, and delete the eM client folder, when you open the application again, a new database will be created.
But to avoid any other users having this issue, can you please click on the “Show error” button when the application crashes again and post it here on the forum?
Thank you, hope new database will help to resolve the issue.
Where Do I find local folder> App Data> Roaming?
I’m running Windows 8.1. Can’t find Local folder > Appdata > Roaming?
I’m also running Windows 8.1.
Make sure you’ve selected to show ‘hidden files’:
start Windows Explorer
select ‘view’ tab page in the top
click ‘options’ icon (right-most icon)
select ‘view’ tab page in the options
scroll to ‘hidden files and folders’
make sure the option ‘show hidden files, folders and drives’ is selected
click [apply]
click [apply to folders]
screen shot:
Now you should be able to see your ‘AppData’ folder.
start File Explorer
goto C:\Users<your user name>\AppData\Roaming\eM Client
3) delete all files in this directory
screen shot:
Problem resolved! Thank you very much!
you’re welcome, John.
Have a nice Sunday!
Glad you’ve managed to resolve the issue, let us know if you come across any other issues or questions about the application.
