I would not upgrade past version 7.0.28822.0. If your email provider is using activesync, you will no longer be able to sync your calendars and contacts if you go pas this version.
Export any local data, uninstall the current version, delete the database, install 7.0.28822, import the local data. Should only take a few minutes and you will be back where you want to be.
You are right Randy. Best to use whatever works for you. One thing I really appreciate about eM Client is that all previous versions are available for download. You don’t need to spend hours searching the Internet for a server that might still have an old copy.
none of this is useful to me.
Many things have been fixed in eM Client since the last comments on this thread. What is the issue you are experiencing Darrell?
