I’m trying eM Client for the first time, and so far i couldn’t get past the config and authentication. Not sure whats wrong, but i’m using eM Client to configure GSuite for Business Account, with Two factor Authentication by Okta, my account is not @gmail.com it has a different domain. Has anyone got similar setup?
I’m trying the default config with imap and smtp from gmail, but it can’t get the account details correcty. If i go Manual, and setup everything manually, servers and ports, i get the user/password pop-up, fill in the info and get an error saying “Server Says Invalid Credentials (Failure)” i have no idea what to try next. Any help would be very much appreciated.
Two factor authentication works with the “Google two factor authentication” if you enable that in your Google account. I use that myself and works fine.
I don’t know if other third party two factor autho methods work which might be your issue with “Okta”.
If you are using the standard Google two factor autho method, just make sure you have (allowed access) in your Gmail account when you add the Gmail account to eM Client & will work fine.
See this thread below that works with (two factor authentication". Same for Personal & Gsuite accts.
Hi @Cyberzork. Tahnks for the reply. Just one question regarding the “just make sure you have (allowed access) in your Gmail account when you add the Gmail account to eM Client & will work fine”
is this done before or during eM Client config?
