When will the stable version of eM Client 9 be available for MacOS? Just bought the upgrade based on the ‘pinned announcement’ to then find out that it isn’t available yet.
Hopefully not far away as the Mac Beta 2 9.0.661.0 from the version history page was last out Jan 20.
Have you tried “checking for update” in the eM Client Beta 2 dropdown menu at the top ? Might be updated since then in the program if u check.
yes have checked and nothing
Yes have checked and nothing
Ah ok. keep checking the version history page for Mac updates then.
