This just started happening recently after the update to 9.0.1708 (when all of the folder tags started showing up). I can now no longer drag/drop GIFs or any JPG/etc to body of an email from a web source without getting the message below. Never had an issue with this prior to the update - dragged GIF’s into my emails all the time with no issues prior to this update. How do I fix?
Here is the message that appears when I attempt to drag GIF/JPG etc into email body:
“Couldn’t add attachment.
Object reference not set to an instance of an object.”
Addl Note: I do have a pro license and am not using the free version if that makes a difference.
Both of which applications? I’m just trying to drag a GIF from a GIF page in Google Chrome to my EM client messages while drafting. How do I tell if I am running the app as user or administrator? This just started happening after the 9.0.1708 update. Worked fine before that.
I re-tested dragging eg: .gif and .jpg files from Chrome and Chromium browsers, and “if you drag it to the desktop first” you can then drag it to any new or exiting eM Client message from the desktop as normal with any attachments from browsers. This has always been the case.
You don’t normally drag it directly to the new or exiting message window or you will get a “Couldn’t add attachment” error as per second example screenshot below which is what you are getting.
So drag it to the desktop first and then drag it to the new or exiting message window.
(Dragging the .gif or .jpg via the desktop first) works as normal.
