eM Client 11.0.1054 on macOS 27.0.1 does not restore the window size and position when running on a secondary display. When the main window is closed on a secondary display, using the red corner button, and then clicking on the running application icon in the macOS dock, it brings the application up on the display currently holding the macOS dock (primary display?), with size and position lost.
If running on the display currently configured with the macOS Dock at the bottom, closing and then clicking the icon restores the window size and position as expected.
I do not believe eM Client 10 had this behavior, or else I would have noticed it in many years of running eM Client on macOS. I tend to run email and chat on one of 2 external large displays, other applications on a second external display, and only use my MacBook Pro internal display as a launcher when at my desk.
Hi @jfmorris
Could you please confirm whether the same behavior occurs if you quit eM Client completely using eM Client > Quit then reopen it, rather than closing only the main window using the red button?
This would help us determine whether the behavior is specific to restoring a closed window or also occurs when restarting the application.
Thank you for bringing this to our attention and for providing such a clear description of the issue.
I can confirm this is still happening with the released eM Client 11.0.1267 on macOS 27.0.1.
If I QUIT eM Client, and then open it again, the window is restored to the proper screen and location. It is only if I close the window, and then click on the running application icon in the dock, that it moves it to a different screen and/or position. In that case, it seems to always come up on whichever screen I have the macOS dock showing on.
Example - MacBook Pro with external monitor, dock on internal display, eM Client on external display. Closing the window on the external monitor and then clicking on the running icon in the dock brings it up on the internal display where the dock is. If I EXIT using the eM Client->Quit menu option instead, when I click the icon in the dock to restart eM Client, it pulls up in the position it was in previous on the EXTERNAL display.
