Hello eM Client Support,
I am experiencing an issue with PDF attachments in eM Client 11.0.1054 on Windows 11.
PDF attachments always open in Microsoft Edge, even though PDF-XChange Editor is configured as the default PDF application in Windows.
I have already performed the following tests:
- PDF files open correctly in PDF-XChange Editor from Windows Explorer.
- The same temporary PDF files created by eM Client open correctly in PDF-XChange Editor when launched directly.
- Changing the default PDF application to Vivaldi does not affect the behavior. eM Client still opens Edge.
- Resetting the saved PDF attachment action in eM Client does not help.
- Updating eM Client from 11.0.865 to 11.0.1054 does not resolve the issue.
Using Microsoft Process Monitor, I confirmed that MailClient.exe starts msedge.exe with the temporary PDF file path as an argument.
Example command line:
"C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe" --single-argument C:\Users\...\AppData\Local\Temp\eM Client temporary files\...\document.pdf
This behavior appears to be specific to eM Client.
Could you please advise whether this is a known issue with version 11 or the packaged Windows installation, and whether there is a workaround?
Best regards
Stefan
