Until version 10.x, it was possible to start eM Client minimized when Windows starts by creating a shortcut to MailClient.exe in the Windows Startup folder and configuring the appropriate settings.
However, with version 11 and the transition to the WindowsApps platform, this method no longer seems to work.
Is there any workaround or alternative method to make eM Client start automatically with Windows and launch minimized to the system tray instead of opening in a full-size window?
I think I’ve found a workaround. Go to C:\Users\NAME\AppData\Local\Microsoft\WindowsApps and create a shortcut of the emclient.exe file located right there. Not the one in the folder with a lot of letters. Do you have one like that? It shouldn’t change with the update
