when I writing a mail and paste inside a print screen (image1) from clipboard, the images are paste correctly.
But If select image1, click on copy (or ctrl+C) and paste this in other row, the editor show me a error image icon (
x), some the path of icon doesn’t exist.
After copy image from emclient editor, If I check with winsnap free, I do not view the image copy in clipboard.
How to resolve this problem?
Thanks
Hi Daniele, what version of eM Client are you currently using?
I tried to reproduce the issue, but it seems all is working fine with my instance of eM Client.
Hi Paul,
my emClient version is 6.0.20617.0
In attach this test case.
Thanks
Hi again, thank you for the screenshot, I understand the issue, but it does not seem to be an issue of the application.
Can you try to install this update on your computer http://www.emclient.com/dist/v6.0.20715/setup.msi and check if the issue persists?
I have install this update on my computer http://www.emclient.com/dist/v6.0.20715 and work fine.
Thanks for your work
No problem, let us know if you come across any other issues or questions, we’ll be happy to help.
