When editing themes, my trial and error, it seems the work flow is:
Find a theme to start with that is close to what I want.
Use Theme Editor, Save-As to save the theme
Edit the theme, click Apply to see the effect
Save the theme settings
The new theme needs to be loaded before the changes stick via: in Settings > Appearances > Import Theme > Apply
Even though I can make changes to the theme and Apply the changes and see the effects, once I click Settings > Save & Close the theme reverts to back to the last loaded. So I have to save or save-as to a new theme file then load it.
Why can’t changes to a theme apply the currently loaded theme? Then I have the option to Save-As as backup? The current workflow isn’t intuitive.
Thanks Gary for the quick response. I discovered that is the required workflow. It’s just wasn’t intuitive to have make changes, then save, then re-load the theme to make it stick. Changes should be persistent with the option to save for backup or distribution/sharing.
By default they will be in C:\Users\yourusername\AppData\Roaming\eM Client\Themes. You may have to enable hidden items in Explorer to get there. /Users/yourusername/Library/Application Support/eM Client/Themes on Mac.
Edit it and save it. Then you will need to restart eM Client, or apply another theme then apply your custom one again.
