Echec de suppression d'elements
Bonjour,
Je trouve cette anomalie dans mes contacts.Je n’arrive pas à solutionner cette anomalie. Merci de votre aide.
[Google Contacts] Échec de la suppression d’éléments dans le dossier ‘[email protected]/Autres contacts’ en raison de l’erreur suivante: Parameter validation failed for “resourceName” : The value did not match the regular expression ^people/[^/]+$
[Google Contacts] Failed to delete items in folder ‘[email protected]/Other Contacts’ due to the following error: Parameter validation failed for “resourceName” : The value did not match the regular expression ^people/[^/]+$
To fix the value did not match the regular expression ^people/[^/]+$ error in eM Client, “Go to eM Client Contacts section”, and then “Right click” on “Contacts” directly under your Gmail account and click “Properties” at the bottom. Then click the “Repair” tab at the top, and finally click “Repair”. The repair can take a little while as it clears the local cache.
This happens due to the Google Other contacts showing in eM Client are “read only”. So to fix that, see my post in the following thread.
Bonjour cyberzork,
Merci pour votre aide, problème résolu.
Bonne journée.
