Draft problems!
I have two BLANK drafts in my Draft folder that I did NOT save there. they were originally completed and sent, with out ever saving them. How do I delete them?
Try right-clicking on Draft folder then click Properties > Repair
There is no repair option in the draft folder properties.
If it is a Gmail or Google Workspace account, you need to right-click on the All Mail folder instead.
I did that and nothing happens.
Please close eM Client, and open a Windows Command Prompt.
Not a powershell, but a command prompt.
Paste in this command: (don’t forget the leading ")
"C:\Program Files (x86)\eM Client\MailClient.exe" /dbrepair
When that is finished, restart eM Client and see if that fixed it.
If not, you will need to remove the Gmail account from eM Client, then add it back again.
That worked. Now the question is; How did blank drafts get there to start with. Particularly, ones that could NOT be sent, modified, or deleted.
