You are missing a Column configuration option which is needed for drafts.
At the moment you can only select (sent / received) but none of those options make sense. It should have a (created or last edited) choice.
Hi Chris, thank you for the suggestion, I’ll forward this idea to the developers for consideration, I agree eM Client could use such column configuration for the Drafts folder.
