If by mistake the above tool is used, YOU MAY LOSE MANY EMAILS WHICH ARE NOT REALLY DUCPLICATES!!!
My ticket #127132 has been issued on 22-3-2021 and till now there is no progress.
Developers latest answer.
Unfortunately we still do not have a simple fix for this, because it is a complex matter. I am sorry for that, but we will still be working on the possible solution. Thanks for your understanding.
Best regards,
Patrik Pukan
As I mentioned in my last reply to your ticket, we definitely did not forget about you, the truth simply is that this process takes time and as soon as it is possible to release the update with deduplication fixed up, we will do so. For now we only ask for your patience.
