I am using separate profiles through commad line and I don’t need profile selection. I am also using lot of SHIFT+xxx shortcuts to run some programs and SHIFT sometimes trigger profile selection when I am starting eM Client and other programs holding SHIFT. Is there any way to disable SHIFT detection when eM Client starts?
I’m not aware of a way to disable Shift key on startup of eM Client. It’s used for bypassing the initial setup wizard as per the eM Client FAQ"a.
https://www.emclient.com/faq-getting-started
Quote: Holding the Shift key while eM Client starts bypasses the initial setup wizard and allows you to directly access and configure your email accounts without being guided through the initial steps, This can be useful if you already have your email settings and want to skip the automatic setup process.
