Dovrei istallare il programma su un altro lap top , devo usare la stessa chiave di licenza ? ho richiedere una chiave di licenza nuova? ho fare un altra procedura?
Grazie
Luigi Paone
Grazie
Luigi Paone
To use eM Client on another computer you need to register / activate with a separate license key using a differant email address for each additional computer to permaently use it, unless you buy a multi license. Contact Sales about multi licenses via [email protected].
Or alternativly if you “don’t want to register for a separate license key” on another computer, the first computer will automatically deactivate when you activate your same license on the 2nd computer.
