Deleting Junk in one click?
How do you clear out the junk folder in one click as is annoying that you have to delete one by one.I have tried the right click and there is not empty junk there is however one on the trash folder, any suggestions?
Regards
Hi, you can select them by ctrl + a and then you can delete them at once, junk email does not always belong to trash (some email servers can put there even wanted emails) so we do not plan to add “empty junk” option to it.
Jan
That seems a little long winded, could it be considered, as I’m sure we are able to check the folder before we delete them.
I am sorry, I was a little confused (almost all featured I test on my outlook.com email), so Gmail, Yahoo and rest of email providers should have “empty junk folder” option implemented (when you right click on it), but it is not possible for Outlook emails because it’s junk is not junk.
So I assume that when you do not see it (like I did) you use outlook/hotmail account right?
Also I am sorry for my previous confusing answer.
Jan
my Gmail has it now I’ve looked (as don’t get any pressently) but my hotmail.co.uk, msn.com & outlook.com do not.
that is what I was talking about in my last post, for Outlook it is not possible. Problem is that it is impossible to detect its “Junk” folder as Junk folder.
Jan
Why’s it impossible on them but possible on Gmail?
Regards
I am not sure, but I know that on newest build it was implemented. I was forwarding information from developer as he told me.
So now in newest public update you should see this option at Junk E-Mail folder also.
Jan
