So it looks like this will be all or nothing? There will not be a way to delete individual suggestions? For example, I have someone whom I have been corresponding with for a decade, but she changed her address two years ago. I do not want to go back and delete all of the sent emails to the old address (because I want to keep them). If that is the case, then I’ll just learn to live with it, because I do like this feature.
I am not a programmer, so I don’t know how hard this would be. But it would be nice if the program would extract those email addresses into a list that you could then edit.
Just adding our voice to the request to be able to delete old email addresses from the contact database.
It’s very frustrating, and has caused many issues for us.
Please address (intentional pun) this issue as soon as possible, as we have many users who are complaining about this massive problem.
But still - as I understand it, there is no easy option to just delete the cache(s) for all suggestions/recipients. As you can see, this is a growing headache for many, and does nothing to address the issue: User confusion around this convoluted feature (read “bug.”)
There is. Just click on the option above next to my indicator (2). So Clear Recipients History.
That is the only cached data.
The rest is either in a Contact, or in a Sent message. It is not cached data. If you want to remove those from being suggested, you will either need to remove the contact’s address, or untick the option indicated above as (3) to remove suggestions from previously sent messages.
@Gary - that is what I have tried, and as I have stated before, it did not work for me: I still get multiple suggestions for contacts that are no longer present.
So, even removing the Contact does not fix the problem, sorry…
And I do wish to keep suggestions from previously sent messages - as long as the address is correct.
I just went through this and although certain bits did not work (deleting the from the recipients history) others did (clearing recipients history), so I got the offending address removed (along with a lot of others). I agree with those who think the UX here is too hard. Here is a suggestion for fixing.
User-saved addresses show up in the Personal address book as they do now.
Addresses collected from Sent or recipient history show up in contacts under “Collected Addresses.”
The suggestion box pulls from address books and Collected Addresses.
Addresses can be deleted manually from collected addresses, just like they’re deleted from an address book.
(Bonus feature) An “add to address book” function when viewing a collected address.
This puts the collected addresses exactly where most people would look for them, and makes deleting them the same process as deleting an address book entry, which is how most people would expect to delete them. The bonus feature makes deleting the whole recipient history (which was the only thing that fixed this for me) less of a problem.
