Can you please create an option to set a default reminder time for calendar entries? This would save many of us the trouble of having to select a reminder time for each appointment. Thanks for such a great program!
this is planned to be in 6th version
regards
Jan
Thanks!
you’re welcome
with regards
Jan
I just downloaded version 6 for a trial and it has no such setting that I can find (6.0.20648.0). There seem to be a number of convenience features missing such as calendar search. This is difficult and doesn’t seem to search the address field. I like the architecture but usability is not the best yet.
Hi Dan, you can find Calendar search under the Agenda view in Calendar, the default reminder setting is under each calendar properties.
The search feature searches the criteria in setup items, click on the arrow in the search field so setup the search folders and options to search for.
This was very helpful. Thanks.
No problem, let us know if you come across any other issues or questions, we’ll be happy to help.
