Is there a way to change the default duration of a meeting from 30 minutes to some other value? Most other applications I have used default to 1 hour (which is what I want) but also allow you to customize the time. Does the capability exist in eM Client? If not, please add to the list of possible enhancements.
Hi Frank, this is unfortunately not possible to adjust in the application, we’ll consider improving this for future releases.
its a must… You should add this fonctionality.
Hi Martin, this option should be included in future releases of eM Client 7.
Paul
