Default calendar
I have something I can’t fix easily, each time I want to create a new calendar ( standard event), it uses by default a gmail calendar that I can’t use. ( the second of the list, which is the “birthday” calendar )
is there a way to fix it ? like being able to define the default calendar used ?
emClient 10.0.3530
The default calendar is whichever one you are in.
So if you click on the Calendar folder (red), the next time you create an event it will have that one pre-selected as the save location. Or, you can always change the folder before you save the event.
well, actually for sure, I switch to the red one ( the first of the list ) but everytime I set a new event, it resets to the birthday one ( which I don’t care at all )
event if I can’t change it everytime, I would prefer to not face the error everytime I set a event.
This works, but I think it would be better if there were also an overall default setting you could make.
So, it’s not a bug for you ? do you want me to document it a better way or email to the support instead ?
