Deep Link to specific email
Is there a way to create a deep link to an specific email message?
What does this mean? Please provide a bit more info on what you’d like to achieve…
Hi, thanks for you response and question.
A deep link is a URL that opens a specific email in the Em Client app. It’s available in Apple Mail, Spark and a few other programs. Here’s Readdle’s explanation on it:
Waiting for this for a long time. It would be awesome (should detect if em client is open or it has to open it).
Suggest then to put a suggestion for that on the eM Client Sleekplan share and vote for eM Client ideas page.
Deep links exist, but they don’t work completely as I expected.
On the pane, when you see the list of all your emails:
  1. Right-click an email
  2. Click on “Properties…”
  3. Under the “General” tab, there will be the property “Deep link”, with a value starting with “https://link.emclient.com/”.
  4. Double click to select all
  5. Right click, then hit “Copy”
Now, with that link in your clipboard, you can access the email… but NOT from the browser. If you click the link from inside an app that’s ON your computer, it will open the email (and launch EmClient itself if it’s not running).
Examples:
  • Put the link in Obsidian, Microsoft Word, the terminal, etc. and click on it? It will work.
  • Put the link in a browser (URL bar, or anywhere else)? It will not work.
I wish there was a emclient:// URI scheme (and an easy way to copy it from the email inside the client), but it doesn’t seem to be the case for the moment.
the reason why we decided to use links in that format is because MCP harnesses are able to work with such URI format. Based on our testing they don’t work well with emclient:// URI format (and yes we’ve tested that hard). So yes currently it won’t work from the browser, but most other use cases should work. Easier getting of the link is planned.
This is awesome information, thank you so much!
Hey Michal,
Thank you for the great product! I’m just starting to use eM Client, particularly for the AI control over multiple accounts, and it’s been fantastic.
It’s great to hear that an easier way to get the link is already planned! Right now, digging into the properties is my only real blocker to building the muscle memory needed to quickly point Claude to specific emails.
Since you are already working on this, would it be possible to consider either of these tiny additions?
  • A configurable keyboard shortcut to “Copy Deep Link(s) of Selected Message(s)”.
  • A “Copy Deep Link(s)” command inside the Cmd + K command palette.
Either of these would be a massive win for productivity when talking with Claude. Thanks again for all the hard work!
+1
Also on Windows, Win+R and sending the deeplink through there works.
Planning on having deeplinks to email threads on my Notion, but they don’t play well with the https://link.emclient.com/v1/item/… style. I would prefer emclient:// protocol still.
