System.Data.SQLite.SQLiteException: SQL logic error or missing database.
I am using windows 8.1 and Norton anti-virus.Tried uninstalling but it does not help.
If I need to set my Norton ins some way - what files should be exclued?
[email protected]
hi, this is broken or deleted database. Have you done anything to it manually?
Anyway you can find your database in “eM Client” folder in C:\Users\ current user \AppData\Roaming\
rename it or delete it and start eM client again. Then setup your account/s and wait until you will receive your data from the server.
Jan
