I consider to perform the data recover function at em client to cleanup any errors,what does this function realy do and do i lost accounts or settings or regular settings,can you please advice me.
Best regards,
Geert Van Osch
Best regards,
Geert Van Osch
Hi Geert, as suggested in the warning you’ve submitted a screenshot of, you may loose some data or account settings that you’ve changed since the last backup. The restore feature will rewrite your database data with data included in the backup, so what you had available when you backed up, will be available in eM Client after you restore from the backup.
Paul
