With v11.0.1267, I had set the theme to a dark theme but the header at the top of the window would get lost when any other program was open so I edited the theme and changed the field mainformheader setting to some obtuse color that Windoze does not typically use & saved the changes. All worked fine until I launched the client later on only to find the theme had resorted back to all black borders. I edited it again & saved it as a new theme this time but only with the same results. As long as I do not close the client, the revised theme works fine. I even went as far as importing a new theme I had downloaded and while that one stayed like you would expect, I cannot get any changes to that one to stick either when I edit the settings. How to fix this…
Sunday 01 November
Hi @Jon_AK
I had a similar issue with saved changes, I did the following:
1./ If you are using the Theme editor do NOT edit in situ
2./ Either export from eMClient to your desktop or download a fresh version
3./ Start Theme Editor then Shut Down eMClient
4./ In Theme editor either select OPEN or +New and follow choices
5./ Do NOT forget to NAME & SAVE your Theme
6./ Start eMClient and Import your Theme
7./ So far all is working OK for me
I see you are using v11.0.1267 you can manually upgrade to v11.0.1389.0
by downloading from Release History for a manual upgrade - I ALWATS do
so rather than allowin the system to do it for me, I prefer to be in control
Bonne chance!
Lucy_C
Not sure what you were referring to in your first item about not editing in situ??
I upgraded as I too usually check the release histor at “the shop” emclient does not save the theme settings in the xml format so i exported my settings then imported the xml but still no joy. The only thing I did that was different from what I was doing before was running the theme editor without the mail client running.
[quote=“Jon_AK, post:3, topic:120315”]
[/quMonday 02 November
Hi @Jon_AK
I am sorry if you did not understand the following:
In simple terms it means IN PLACE in this instance within eMClient
Again sorry, maybe lost in translation, my native language is French
though I did write directly in English.
Bonne chance!
Lucy_Cote]
It turns out I was altering the wrong control. I used the “pick element” the first time and it pointed to the element Forms → Forms → MainForm so i changed the MainFormHeader element which would not stick even though the changes were still there when re-opening the editor. I left that setting alone, used the “pick element” tool once more and this time it pointed to Forms → Forms → FormHeader. This time the setting held.
Thank you for taking the time to help me out with this one.
Hello Jon_AK, thank you for coming back with the solution. It’s good to hear the theme changes now stay after a restart when you edit the FormHeader element. If you run into any other problems with themes, feel free to start a new topic and mention your eM Client version. Have a nice day!
