I use emClient’s existing shortcuts quite a bit but the two I use most in other apps don’t exist, Empty All Trash Folders and Empty Junk Mail. Is there a way to create those and, if not, how do we submit a feature request. Thanks.
Hello.
Open eM Client and at the top click on “Menu” then click on “Settings”. There, you will see “On exit, empty trash” check that box. Click on “Apply” “Save & Close”.
Thanks, I know about that one and do have it checked.
If you want to do it manually, first make sure both the Junk and Trash options are displayed in your Favorites.
Then just right-click on the folder and choose Empty Trash or Empty Junk, and it will empty the Junk or Trash folders from all of your accounts at once.
I was hopeful emptying trash from favorites was the solution. Not so.
The process stopped after about 5 minutes and would not start again. Trash bin is still full.
Does uninstalling and reinstalling eMclient give this emptying process a fresh start?
