I have just installed em Client. When I want to write a mail using a custom colour, I can create the colour, but it will not save. Why is this this and how do get it to save the colour?
Hi Andrew,
It will save in the draught of the email or when sending, but otherwise this is a per email choice.
In the mail font settings you can set a repeatable - preferred font or colour only in Read,
not in Compose ( Menu > Tools > Settings > Mail > )
Maybe the use of templates might appeal to you.
Menu > Tools > Settings > Mail > Templates and Signatures
Click Mail Templates
Then click Add Template
Play around in this section - The choices are numerous…
I simply couldn’t show all screenshots here.
Save the template giving it a descriptive name using abbreviated terms.
and assign it to the appropriate purpose - New mail - Replies or Forwards.
Check my first graphic - above
You can create multiple templates for each category and when needed
select the appropriate template from the list.
Peter E
Thanks for the reply, Peter - and sorry not to have got back sooner. I didn’t have notifications switched on!
When I go to custom colours, it asks me to define a colour. When I’ve defined the colour I click ‘Add to Custom Colours’ and it appears in the palette. However, it’s not saved there for when I want to use it again - which is the whole point of creating it. Surely it should do that?
Andrew
